Need help on a scripted validator
Rachid El Mansouri January 12, 2023
Hi experts,
I have a problem on my following scripted validator.
I want to prevent transition if value of custom field "Origin" is different to "IVV".
The script always return false even if value of my single select is equals to "IVV"
Thank you for your help
def cfManager = ComponentAccessor.getCustomFieldManager()
def OriginCf = cfManager.getCustomFieldObject("customfield_10404")
def OriginValue = issue.getCustomFieldValue(OriginCf)
log.warn("OriginValue =  "+ OriginValue)
// this return IVV
if (OriginValue.equals("IVV"))
    return true
else
    return false
Fabio Racobaldo _Catworkx_
Hi @Rash ,
is Origin field on the transition screen ? Moreover could you indicate custom field type?
Fabio
Hi  @Fabio Racobaldo _Catworkx_ ,
Thanks for your quick reply.
The Origin field is "Select List (single choice)" and is on the screen otherwise it will not get its value.
Hey @Rash ,
try this code :
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.customfields.option.Option;
import com.atlassian.jira.issue.fields.CustomField;
IssueManager issueManager = ComponentAccessor.getIssueManager();
CustomFieldManager cfManager = ComponentAccessor.getCustomFieldManager();
CustomField OriginCf = cfManager.getCustomFieldObject("customfield_10404");
Option originValue = issue.getCustomFieldValue(OriginCf)!=null?(Option)issue.getCustomFieldValue(OriginCf):null;
// this return IVV
if (originValue!=null && originValue.getValue().equals("IVV"))
return true
else
return false
Hope this helps,
Fabio
This works.
Thanks for your help @Fabio Racobaldo _Catworkx_
Have a nice day.
I'm happy for that. Have a nice day @Rash
