Hello all!
I am trying to write a event in JWWE in order to evaluate if the field Sprint changes for an issue to a value of an active sprint to set the field label to "NotPlanified" and if the Sprint is not active to set de value of Label to "Planified"
I have tried this:
{% if {{ issue | sprints("active") | first | field("id") }}>0 %}
{% set issue.fields["Etiquetas"] = "NotPlanified" %}
{% else %}
set issue.fields["Etiquetas"] = "Planified"
{% endif %}
But when testing it shows me the following error
(string) [Line 1, Column 8] parseAggregate: expected colon after dict key
Hi Rosana, I'm Melanie from the Appfire support team; you can check the configuration I set on my end below:
{% if issue | sprints("active") | first | field("id") %}
NotPlanified
{% else %}
Planified
{% endif %}
You can additionally set a condition for the post-function to avoid the post-function being triggered when the Sprint value is deleted.
{{ issue.fields.<sprint field> != null }}
If you have further questions, you can raise a ticket on our support portal: https://appfire.atlassian.net/servicedesk/customer/portal/11
Hi @Melanie Corletto (Appfire)
Thanks for your answer. I tested it but no matter if it is a active sprint or not it is always assigning NotPlanified.
am I missing anything?
NotPlanified
{% else %}
Planified
{% endif %}
Okay I have tested but I have a question.... I want the value to be replaced, any time the sprint is changed from an active to an inactive sprint.
Now the field label is updated the first time I move the issue from one sprint, let say from an inactive to an active, but if I move it from an active to an inactive sprint the value is not changed
