Need help on boards
Attili Venkata Ravi Kishore November 10, 2022
Hi,  I have a JIRA project under which earlier 3 boards were created for different reasons one kanban board and other 2 scrum boards.
today i have create another scrum board to fresh start my scrum work. However, in the scrum backlog i created, i am seeing a list of issues in backlog including epics which i don't want. What is the way to remove all epics and backlog items from this newly created board. Is there a way to do that by creating a filter, if so, can you pls write a sample filter here . if it is not possible, do i need to create a new Project with a scrum board. pls let me know
Fabio Racobaldo _Herzum_
Hi @Attili Venkata Ravi Kishore ,
Go to your board administration section and edit filter query .
your filter should be something like project = YOUR_PROJECT_KEY and issuetype not in (Epic)
Hope this helps,
Fabio
Thank you. That worked. However, still it is showing previous versions of previous boards. How to exclude them in this board? Appreciate your help
FREE
