There are some example validator scripts at https://library.adaptavist.com/search?term=validator
Hello @Ravindran Subbiah ,
Do you have installed some add-ons on Jira, like JSU, JMWE of Scriptrunner?
With one of this add-ons it is possible to put a field-required validator on a workflow transition.
regards, Marco
I dont know whether this addons are available. but i know script runner exist
If Scriptrunner is installed you can have a look at https://scriptrunner.adaptavist.com/latest/jira/recipes/behaviours/field-required-on-transition.html
I think this validator is available in cloud and not in server
