I was able to integrate testlink and Jira successfully. I am now able to create a bug in Testlink and the same reflects on Jira.
I need similar integration for Jira user stories/requirements with TestLink.
Is it possible? If yes could you please guide me how to do it?
Thanks in advance!
Syed
Hi All
Can i integrate testlink and Jira ?
Hi Syed.. Could you help integrate testlink and Jira successfully, create a bug in Testlink and the same should reflect on Jira.
Could anyone please let me know the solution for this. I am also looking to link the test case from test link to jira user stories. Your help is much appreciated. Thank you.
Testlink connects to Jira via the REST API. This question should be asked of Testlink, not Jira.
This would be a Testlink question, as the functionality comes from there. Testlink simply manipulates the Jira REST API when configured. It does beg the question, though. Why would you be opening anything but bugs from a testing tool? I wouldn't be surprised if it isn't possible, since it doesn't seem to be something that most people would do.
Hi Dev, I will put the question in this way..
I am using JIRA for User Stories and using TestLink for Test management( writing test cases for each JIRA user story).
I want to know is there a way to link JIRA user story to TestLink test case/ test suit.
Can I generate a link in JIRA that can take me to TestLink test case/test suit.
Need to know if it was resolved.I'm facing same issue. Thanks!
Does anybody receive the solution of this problem?
i need to link Testlink Test cases with Jira user stories along with Bug (Created from Testlink) should reflect as sub task under users story..
