×Hi,
I have a listener in place for a particular functionality. This listener is meant to work on a select list of projects.
I now want the listener to get the list of projects from the database, instead for manually adding each time into the listener.
Can I please get some help on what needs to the appended to the existing listener in order for it to get the select list of projects from the SQL database.
Hello @Aisha M
Do you need to get the list of projects from the database?
Wouldn't the script below help?
def projects = ComponentAccessor.getProjectManager().getProjectObjects()
Up until now, the projects for which the listener must work is separately mentioned on the listener page under 'projects".
But now, we want the listener to get a specific set of projects from the database table . .
So I want to know how to specify in the listener for getting a particular set of projects from the db . .
So, as far as I understand you need to connect the Jira database and get the result of the SELECT statement within your script linstener. Is that the case?
In either case (whether it is a Jira database or an external database) I'd recommend checking Script Runner's Connecting to databases link.
@Tuncay Senturk _Snapbytes_ Below is a initial snipped of my code . . .I wanted to include in the script to fetch the results from the jira db we have.
Thanks for providing the script, but the mysterious part is not there.
I need to know where are the projects stored? Is it the Jira projects or do you want to listen to the projects which are listed in a database table that is created by you just for this purpose?
@Tuncay Senturk _Snapbytes_ Basically the script copies the Assignee name from TFS to the Assignee in JIRA . . . (Both tools are connected via a TFS4JIRA synchronizer)
These projects are residing in JIRA . . . But instead of adding the projects individually to the listener "project field' every time I create a new project, I want the listener to check the database & get the list of projects automatically from a table
I hope I'm making sense :O
Ok, let me ask you another question then.
Why don't you use a custom listener which is applied to Global (All projects) rather than selecting those projects manually?
That is because, this custom listener is limited to only a few (say 100) projects that is just synchronizing itself with information from the TFS . .
So, over time, the number of projects could increase, so kinda becomes a hassle adding each project manually to the "select project list" . . . so looking for ways to gets this specific set of projects from the jira SQL database instead. .
My theory is, I want the listener to first look for the sql table with the list of projects (based on a criteria), and then run this listener script only for those projects . .
I'm so sorry for confusing so much :D I'm so desperate to find the code that could make this work
Yeah, that's doable but still, there is a manual job. I mean you can get all projects list from the database table, but you would not know whether they needed to be used in that listener.
To make it clear, assume you have 250 projects and right now you are synching (say) 100 of them. The question is where should the listener know which 100?
If you have a table specifying those tables, it is easy to handle. Otherwise, you need to specify each project manually within the job (either by code or configuration)
I hope I was clear.
@Tuncay Senturk _Snapbytes_ Yes, I could have a table specifying about those set of projects alone . . I need to know what the code should be inorder for the listener to fetch info from the table . . . at the moment, the listener is functional & working fine. .
Hello again,
I am not sure if it is a good idea (in terms of performance) to hit the database every time to get that list but this might be a solution.
First, it gets the projectId values from the database table and collect them in projectIds variable, then check the issue's project Id.
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface) ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default")
def sqlStmt = """
SELECT projectid FROM customtablename;
Connection conn = ConnectionFactory.getConnection(helperName)
Sql sql = new Sql(conn)
List projectIds = new ArrayList()
try {
StringBuffer sb = new StringBuffer()
sql.eachRow(sqlStmt) {
projectIds << "${it.projectid}"
finally {
sql.close()
if (projectIds.contains(issue.getProjectObject().getID())) {
do what you want here
I haven't run the code but it might be a good point for your script.
Please let me know if you have further questions
Thank you thank you thank you for me helping out ! And that is definitely not a small snippet of code , that looks bigger than the actual code itself . . lol
So, I ll need to append this at the start of my script ? Will try and test it out
Haha, that's 'for sure' not a small snippet. This code gets a connection from the Jira database, executes select to the table (you need to change table name and column name part), and eventually, it checks whether the changed issue's project is included.
So, your code will look like;
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.event.type.EventDispatchOption
import com.atlassian.jira.event.type.EventTypeManager;
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.util.ImportUtils;
import com.atlassian.jira.security.groups.GroupManager
import com.atlassian.jira.issue.CustomFieldManager
def issueManager = ComponentAccessor.issueManager
def issueService = ComponentAccessor.getIssueService()
def userManager = ComponentAccessor.getUserManager()
def CustomFieldManager = ComponentAccessor.getCustomFieldManager()
def sqlStmt = """
try {
finally {
sql.close()
if (projectIds.contains(event.issue.getProjectObject().getID())) {
//your code here
def cField = CustomFieldManager.getCustomFieldObject("customfield_1234")
//log.info("Cfname: 1 ${cField.name}")
Hello
Even the code is not complete and it is hard to guess but I think the script does not get the list from the Jira database.
It works for the projects which are under the "Sub-domain" category in your Jira.
There is a comment-out section in which I believe they first added infra project keys manually "ISPE,IRBR, ...". Then I think they switched to collect those projects under one category which is also a good idea.
Oh okay ! I was just so confused as there seemed no SQL statements present to get any info from the db . . . Makes sense now . .
Yes, the code above has the section (I believe it would work after a few touches) to get the list from the database
Below the code, there is a section to put your actual code.
//your code here
def myIssue = event.issue
//log.info("myIssue: 1 ${myIssue.key}")
String cFieldValue = myIssue.getCustomFieldValue(cField)
def issueObject = issueManager.getIssueObject(myIssue.key)
I hope it helps
Also, can I improvise the below section of your code with additional SQL statements to find the correct projects
def sqlStmt = """
Maybe with something like this,
def sqlStmt = """
USE <Dtatabase context>
GO
SELECT projectid
FROM <table name>;
Will this modification make sense to the listener ?
Yes, of course, you can use any SQL statement. Bear in mind that you have to use the same column name in your code which is returned from SQL statement.
SELECT projectid FROM ...
${it.projectid}
It can return multiple columns
SELECT projectid, second, third FROM ...
and you can get anyone as
${it.projectid}
${it.second}
${it.third}
Hi @Tuncay Senturk _Snapbytes_ , thank you soo sooo much helping out :):) Was able to get the scriptrunner to work for the projects from the DB for a particular domain.
Just one doubt, I'm trying to capture projects through a service desk form to add to the database along with their scrum board ID.
Hi @Aisha M
I'm glad that you managed to get it worked.
I'd recommend using a number field to get the board ID value through a JSM ticket form.
And of course, please let me know if you have any issues with the script
@Tuncay Senturk _Snapbytes_ So, instead of the WORK field , can we use a input field to maunally input the BOARD ID (this will be used by admins ONLY, to add select projects to the DB) , and then add that value in the to the board ID of the table ?
Indeed, it is doable. You can easily use a number field and the admins can paste the Board ID and update the table accordingly. But in that case, you will not have the project ID values to compare.
I mean, if you want to change your script listener and check whether the issue is in the boardID values, I don't know if there is a way to do it. Anyway, let me know what exactly do you plan to do, and I will try to find out a solution.
@Tuncay Senturk _Snapbytes_ We already have one to map particular project to a field value. That script has been added to the workflow. So, the db table is updated with the project key & a corresponding field value. (Have added the script above)
So, the service desk request form has three questions.
Project ID-
Team Operation - Add/Remove
Work - (Drop down field)
So, once the service desk form is submitted. The above values are added to the DB. If the operation is remove, it removes it from the table.
I wanna do the same, but instead of the custom field. I wanna add the board ID. But I want JIRA to know it is that particular projects board ID . Or maybe I want the script to pick that projects board ID from the project key & add it to DB. dunno which is the right way
Hmm, a project may have multiple boards, you can't pick a project's board id and add it to the DB. In this case, it is better for admin to fill in the id value manually.
@Tuncay Senturk _Snapbytes_ Yes, that is no problem . . . We can have have multiple boardID for a same project in the table. (there is another listener which picks the baordID from the table & applies it for the project)
I want to manually input the BoardID (thro a number field) & the project key from the service desk form. And then use those values to populate the db table (the workflow script shared above, takes this info and updates the table in the db)
That's totally understandable, everyone does not need to be a code geek.
Below is the code how to get a number custom field value.
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
def boardIdField = customFieldManager.getCustomFieldObjectByName("Board ID")
def boardIdValue = issue.getCustomFieldValue(boardIdField) as int
@Tuncay Senturk _Snapbytes_ Thank you for saying that :) wow, thanks ! Is the below script alright ? I changed the code with what you had provided :)
At first glance, the code seems alright :)
@Tuncay Senturk _Snapbytes_ I get an error for the below line,
ERROR - Cannot find matching method. com.atlassian.jira.issue.MutableIssue#getCustomFieldValue(java.util.collection<com.atlassian.jira.issue.fields.Customfield>) Please check if declated type is correct and if method exists
I think you used the one which is cast to MutableIssue.
Can you use event.getIssue().getCustomFieldValue... instead?
Please let me know if it helped :)
I supposed it was a listener.
So, how do you define the issue variable?
From above, I can see that you use the below code.
That's why I asked you to use event.getIssue()
Oh ok, it should be because of this, sorry
instead, please use
def boardIdField = customFieldManager.getCustomFieldObjectByName("Board ID")[0]
No no, its okay :)
Also, my script defines def cfm = ComponentAccessor.customFieldManager
So, should it be ,
def boardIdField = cfm.getCustomFieldObjectsByName("Board ID")[0]
def boardIdValue = event.getIssue().getCustomFieldValue(boardIdField) as int
or
UPDATE - THE BELOW CODE DID NOT GIVE ANY ERRORS NOW
Will try to submit a Service Desk request form & update u if it works :D
That's not a dumb question, that's a great question.
getCustomFieldObjectsByName method returns an array as there can be multiple custom fields having the same name. Assuming you have only one, I used [0].
If you use getCustomFieldObject(10xxx) where 10xxx is the ID of the custom field, then you would not need to add that ([0])
Hope it is clear now.
Thank you ! That makes sense now :):) And super grateful to you for helping me every step of the question, even if its a super silly one :):)
As I mentioned before, everyone does not need to be good at reading APIs and coding scripts ;)
Yes could you please create a separate post, it became very hard to track.
Please do not forget to mention my name :)
in case you did not get a notification :)
