Need help with Scriptrunner Behaviour script
Aisha M
I have the below script & it behaves the below mentioned way,
* Makes a drop-down field mandatory when the current Epic Due Date value is changed to a latter date
* Makes the drop-down field mandatory when the Epic Due Date value is completely erased
* Hides drop-down field when the current Due Date value is changed to a earlier date
* Stays hidden when an user randomly edits an Epic issue for other field values
But the problem I have is, sometimes an user creates a new Epic without a Due Date value (Maybe they wanna add a date after sometime) . And even in that case, when they try to fill Due Date for the first time, the Reason drop-down field becomes mandatory. Is it possible to avoid in that scenario alone ? (like, when an user already created an Epic & tries adding the Due Date for the first time, I want the field to be hidden ?)
Leo
Hi @Aisha M,
you can simply place another condition to check Due Date's value. if it was null and gets value now you don't need to perform any changes, something like below
if (underlyingIssue){
def dueDate_value = underlyingIssue?.getDueDate()
if(dueDate_value){
def duedate = getFieldById("duedate").formValue
def textField = getFieldById("customfield_10002")
if (duedate != "" && dueDate_value >= duedate){
textField.setHidden(true)
textField.setRequired(false)
else {
textField.setHidden(false)
textField.setRequired(true)
BR,
Leo
Aisha M
Hi @Leo , Thank you for the comment. I replaced my code with your above input. But now the behaviour doesn't work as intended. The text field doesn't become mandatory when the value is changed to a latter date
Leo
@Aisha M , you mean when Due date has some value and changed to later date doesn't set text field as mandatory?
Aisha M
@Leo Yes, the text field did not become mandatory when the Due Date was changed to a latter value from the existing date. Infact, nothing happened once I replaced my code as below with the above mentioned snippet.
import groovy.transform.BaseScript
import com.onresolve.jira.groovy.user.FieldBehaviours
import java.sql.Timestamp
@BaseScript FieldBehaviours fieldBehaviours
if(dueDate_value){
else {
Leo
@Aisha M , I haven't modified your script except placing a condition to check whether current issue has due date or not.
maybe you can add the condition in else part by removing it from top
BR,
Leo
Aisha M
@Leo  Thank you for the comment, but I have gotten the code fixed. :)
