Hi all,
I am trying to create a Queue for our approvers. The Queue should show the users only issues which require his/her approval.
Till now, I have this: issuetype = Change AND status in ("Awaiting CAB approval", "Peer review / change manager approval")
Till this point, it works fine and returns the expected tickets. Once I add AND Approvals = myapprovals() to the end, it says that no matching issues are found.
I have also tried all other allowed options such as myPending(), .
Why is this not working? What am I doing wrong here?
Anna
I am having this issue also - was there a resolution? I'm not able to query the Approvers field. I'd like to send a subscription email to all users that have an Approval in their queue - ie. = CurrentUser().
I would also suggest some other approach - as You refer to user being approver, he/she should be listed in respective user picker field. So maybe referral to currentuser() would help
Sorry for the late reply....exams.
We do have a custom field of type user picker set up. I have even tried setting myself as an approver. When I run only the first part of the query, I get the list of issues and can see in the issue navigator, that the approvers are listed. Once I add the second part, no issues are found. This is the same for mypending() or even approver(username) and currentuser().
KR
Anna
Hi Anna, I would have thought mypending() would do work. What if you drop the status = part just as a test?
issuetype = Change AND Approvals = mypending()
obviously this requires that there are issues pending for you.
or try pending()
just trying to zero in on the behavior here.
Hi Jack,
Yes, Service Desk. As mentioned below, any combination added to the original query results in no issues found.
KR
Anna
