Need to Migrate Monday Project into Jira cloud?
suneel babu
Dear community,
I just need to Migrate a Project in Monday.com which has lot of different boards in it. So, I want to Migrate this project into the Jira cloud platform in single go just like project migration in jira platform.  Basically the customer wants to switch into Jira cloud from Monday.com.
Any help or suggestion's are much appreciated.
Thanks in advance.
Suneel Babu
Vronik
December 10, 2024
suneel babu
Hi @Vronik ,
Thanks for your Quick Response and References.
I've already gone through  those documents earlier which was mentioned above by you, It is saying that , If the Monday project has Multiple Boards , we have to create Multiple Projects accordingly, Instead of that, Can we move all the Boards into Single JIra Business Project Like that ???
Suneel Babu
Prachi Bolar
December 10, 2024
hello,
Welcome to community :)
the above shared links should help you here or this app as well : https://marketplace.atlassian.com/apps/1225780/monday-com-jira-integration-2-way-sync-migration?hosting=cloud&tab=overview
Thank you,
Prachi
suneel babu
Hello @Prachi Bolar ,
Thanks for your suggestion, Let go through it & get back to you.
Suneel Babu
