Need to cascade between two custom fields
Nandeesh M S December 2, 2015
Here is my detailed requirement,
I have two custom field namely
1."RYG" with dropdown values Red, Yellow, Green.
2. "Overall Status"
Now if i select Red in "RYG" custom field Action Required value should appear in "Overall Status" custom field.
Same way if i select Yellow -> Monitor and if i select Green -> On Track values should appear.
Is there any way way/scripts to achieve this. If you any scripts please share.
JIRA version 6.3.15
Thanks in Advance,
Nandeesh
Fabio Racobaldo _Catworkx_
Hi Nandeesh,
you can use a behaviour for this purpose.Please install ScriptRunner for JIRA (https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner/server/overview) and setup the following behaviour  on RYG custom field :
FormField ryg = getFieldByName("RYG")
FormField overallStatus = getFieldByName("Overall Status")
def rygValue = ryg.getValue()
if(rygValue!=null){
	if(rygValue.equals("Red")){
   		overallStatus.setFormValue("Action Required")
	} else if(rygValue.equals("Yellow")) {
   		overallStatus.setFormValue("Monitor")
	} else if(rygValue.equals("Green")) {
   		overallStatus.setFormValue("On Track")
Hope this helps,
Fabio
Hi Fabio, Kudos to you. it worked perfectly. Many thanks for your kindly help :) Thanks, Nandeesh
You're welcome :)
Yogesh Mude
December 15, 2018
HI @Fabio Racobaldo _Catworkx_
We are looking for below requirement and i started searching around but this will not be possible with inbuilt Jira functionalities like cascading and all..
I am thinking of using the script we can do this but for maintaining the script and adding a new option into it will be like hell...
And each field contains more than 100+ options...any suggestions will be helpful for us.
  • Organization is associated with Component i.e. based on organization the options for Component are loaded.
  • Component is associated with Category i.e. based on Component the options for Category are loaded.
  • Category is associated with the ticket type i.e. based on Category the options for Ticket type are loaded.
