Need to setup roadmap in project
lisa
I am trying to set up the roadmap in all of my projects. However I have a wrong setting in only one of them. Can you help me figure it out?
This is the error I am getting
When I click on the "edit filter query" I land hereScreenshot 2021-02-05 at 13.35.37.png
What do I have to do?
Jack Brickey
Disclaimer,  I’m not using road maps at the moment. However, my guess is that your board is spanning multiple projects. This isn’t supported with roadmaps, it is meant for a single project. Check your boards filter to see if this might be the case.
Jack Brickey
Looking a bit closer it seems that the filter is a single project but to be sure click on the edit filter query and see what is there.
Bill Sheboy
February 5, 2021
Hi @lisa
Please note the message at the bottom of the general settings page:
"We can't show the projects on this board, because the board's filter doesn't specify any..."
  • Has the project been archived or renamed recently?
  • Does the board work for this project?
Jack Brickey
As Bill indicated it seems that the PROD project does not exist or has been archived.
lisa
I just fixed it! thank you
Like Bill Sheboy likes this
Bill Sheboy
February 8, 2021
Hi @lisa
I am glad to hear you fixed it.  What turned out to be the problem and your fix?
lisa
It was indeed the wrong project linked.
秦怡洁 June 21, 2021
@Jack Brickey @lisa Hello, how do you configure the roadmap in the board settings, there is no such option in my board settings
lisa
Hey guys!
Thanks for trying to help me but I am still super lost. If I go to "edit filter query" this is where I land...??? @Jack Brickey
@Bill Sheboy this project has not been renamed. The active sprint board does work too... any ideas?
