Hi Team,
I need to Hide the custom field in other states. and it should be displayed in Particular State.
I have created custom field and added in Edit/View screen.
Example Workflow: New-->InProgress-->Resolved-->Closed
When i moved to resolved state I need to display the custom field in edit screen. And that custom field should not be displayed in any other state.
Note: I'm aware of Transition Screen Popup screen. But i don't want to show Popup Screen when i moved from Resolved to Closed Transition
Hi @Prathap DL
Unfortunately in cloud there isn't any way to achieve that. Only in DC version and only with scriptrunner. Currently on cloud scriptrunner supports behaviors only on create screen https://docs.adaptavist.com/sr4jc/latest/features/behaviours
Hi Prathap,
The only way to do this as you want would be to possibly use the ScriptRunner Behaviours app.
There's workarounds using transition screens as you mention.
