if I'm within a project and I want to create/modify an issue, then it should not be possible for a 'standard user' to change the project. Is this possible?
Thx
Herb
Welcome to the community!
What do you mean change that project? Edit your project settings or move a ticket to another project?
Regards
HI,
e.g. if I'm selected Project ABC and I want to create a new issue, then the field Project should only show ABC. We want to avoid, that the user can create an issue for another project, then the selected one.
Bye
This would only work if the user has access to create to a single project in your instance. If they have access to create on multiple projects you won't be able to lock it.
Cheers
This means if Tom has access to Project A, B and C, then he can always choose between Project A, B, C when creating an issue, right?
Bye
