New Issue Type with same hierarchy level as epic does not automatically associate the 'epic link'
danmachen
We have created a new issue type which is defined within the issue type hierarchy to share the same level as Epic, so that it can be viewed on the Timeline and share the same functionality as an epic type.
However, when creating a child of this new issue type through the Timeline view, the child issue type does not automatically populate the 'epic link' field that would normally poulate when creating a default Epic issue type.
Is this something that needs tobe configured or is this functionality only available for standard epic issue types?
danmachen
Hi, I jsut wanted to update this ticket with my new learnings!
This action is possible, new issue types can be defined with the same hierarchy level and have the same functionality as epics on the Timeline/Roadmap.
Once we removed mandatory fields from our screen then the functionality worked as expected.
@Sunny Ape - This should be possible under the latest jira experience. Thanks for your support.
Sunny Ape
January 18, 2024
Yep, that's right.
If you Google 'jira issue same level as epic' the first result is where the question has been asked before and a detailed answer provided.
danmachen
Thank you for your quick reply!
Like mardrik likes this
