Next generation Project Backlog management
Deleted user October 29, 2018
In scrum projects, I can manage my Epic by simply dragging stories into Epics in the Backlog board.
Next generation project has a backlog but it doesn't have EPIC or Features on the sidebar.
What is the easiest way to assign/Move stories into EPIC for Nxt Gen Projects?
Tawhid
Alexey Matveev
October 29, 2018
To add issues from the board and backlog:
  1. Navigate to your Board or Backlog.
  2. Hover over the issue and select more (•••).
  3. Select Add to Epic*. Issues can only belong to one epic at a time. If an issue already belongs to an epic, the Add epic option will be replaced by Change Epic*.
You can find more info here:
https://community.atlassian.com/t5/Next-gen-articles/Working-with-epics-in-next-gen-Software-projects/ba-p/896953
Thank you for the quick reply. Can I add roadmap feature in the Scrum or Kanban projects?
Alexey Matveev
October 29, 2018
No, You can not do it. The Roadmap feature is only available for next-gen projects
Thank you
Alexey Matveev
October 29, 2018
You are welcome! If my answer helped you, kindly accept my answer.
michael ryan
Where is this Backlog?
Alexey Matveev
October 29, 2018
Go to project settings -> features and turn on the backlog feature.
Like Charlie Greenman likes this
