I have 2 projects, one classic one next gen, I created a scrum board to view tasks from both project onto and to run both in the same sprint.
(/) The filter is accurate as issues from both project are appearing under it
(/) The status that I need to show on backlog is accurate for both projects under the columns settings
(x) Issues from the next generation project isn't showing on under the backlog so I can include it in the sprint.
Is there a solution?
can you share your boards filter and maybe a screenshot of the backlog so I can get 'eyes' on your situation?
oh, wait maybe you are dealing w/ known bug of issue in NG w/in an Epic not showing in backlog.
Yep, there is an open ticket already that relates to this
https://jira.atlassian.com/browse/JSWCLOUD-17987
