I used to be able to create a new Issue ( C ) whilst viewing a Sprint. When the Issue was created there was an option ( link ) to add the Issue to the current Sprint. That no longer seems to be an option.
Is there an option for this?
TIA - Vijay
@Vijay-Kumar Solanki you should have the option to add it to the current sprint on issue create as described here: https://support.atlassian.com/jira-software-cloud/docs/add-issues-to-an-active-sprint/
Thanks. I have the ability to add an issue to an existing Sprint. What's missing is the ability to Create and Close a Sprint.
