Hi all!
I saw a lot of answers to similar questions and I have definitely the same issue. However, there is no Resolution field in the rule settings. May somebody help me to understand why? And how could I manage it?
It is software project type, cloud jira
Hi @Diana Yavorska - Welcome to the Atlassian Community!
Unfortunately, you cannot currently change the Resolution value for Team-managed projects. You should vote for and follow the feature request here:
Welcome to the Atlassian Community where peers try to help each other.
The first thing to check is whether the resolution field is associated with the project and in particular on a screen associated with that transition.
Automation only offers fields associated with the project in the field configuration and for a transition in the associated screen scheme.
Once you have checked those places if you are still experiencing issues then we can dig deeper in to your configuration.
Phill
Hi @Phill Fox
Thank you for your attention to my question. On the general screen, I see data from this field. But I didn`t find any place where I could change this field. So, currently, the data in this field changed automatically.
