Not able to add scope: read:field-configuration:jira to Oauth3Lo App
aditnegi1
February 1, 2022
While trying to call GET /rest/api/3/fieldconfiguration, on the documentation(https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-field-configurations/) it states that -
OAuth scopes requiredmanage:jira-configuration
I added the scope to my Oauth3LO app but still while calling the API I got this response
{"errorMessages":["Access to the resource was denied due to missing scope grants.Your app was granted the following scopes: [read:jira-work, offline_access, write:jira-work, read:jira-user].\nThe resource can be accessed by having one of these groups of:\n * scopes: [read:field-configuration:jira]\n * deprecated scopes: [manage:jira-configuration]\n"]}
And I couldn't find the scope read:field-configuration:jira in the permission sidebar of developer.atlassian.com/console/apps  . Is there any other way to add this scope?
James Richards
February 2, 2022
Hi @aditnegi1
A few things are going on here. We rolled out new granular scopes on the 26th January, which included many new scopes, and then rolled them back to the original scopes as we had deployment issues with the new scopes.
manage:jira-configuration is an original scope, and should work. What's likely to have happened here is that you saw the new scopes screen which doesn't have this older scope.
You should see the correct scope screen now. Can you try the developer console again, check for the manage:jira-configuration scope, add it and then re-authenticate your app?
James.
Jeff Haynie February 16, 2022
any updates on when we can expect this fixed?
Rohan Goel
February 1, 2022
In 3LO app the scopes configuration has these scopes
After oauth it asks for `read:field-configuration:jira` scope which isn't present in above screen???
James Richards
March 2, 2022
Hi  @Rohan Goel
You need to update to the new scopes. They are visible now in the Developer Console. You should see a banner at the top requesting you to update.
James.
George Cairns
May 4, 2022
Hi @James Richards
Im trying to do the same thing - I still get the old list of scopes as pictured above, but there's no banner to allow me to update. Has this been rolled out everywhere?
I'd love to be able to get at my sprint data 🤩
