Not able to connect mysql db using scriptrunner
Vedant Kulkarni
February 1, 2018 edited
I want to connect to MySQL DB by using script runner. I applied behavior for this on a custom field. I paste the driver jar file in <jira-install>\lib and also studied this scriptrunner tutorial https://scriptrunner.adaptavist.com/latest/jira/recipes/misc/connecting-to-databases.html . But I still getting this error. Am I doing it in right way?
script:-
def driver = Class.forName("com.mysql.cj.jdbc.Driver").newInstance() as Driver
def prop= new Properties()
prop.setProperty("user","admin")
prop.setProperty("password","123456780")
def conn=driver.connect("jdbc:mysql://localhost:3306/ISE_DB",prop)
def sql=new Sql(conn)
try {
sql.eachRow("select count(*) from Customer_View") {
log.debug(it)
} finally {
sql.close()
conn.close()
2018-02-01 12:17:45,242 http-nio-8080-exec-11 ERROR admin 737x410x2 73padh 0:0:0:0:0:0:0:1 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] Script function failed on issue: (create issue) project/issuetype: IFT/Task, user: admin, fieldId: customfield_10202, file: <inline script>
java.lang.ClassNotFoundException: com.mysql.cj.jdbc.Driver not found by com.onresolve.jira.groovy.groovyrunner [173]
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1532)
at org.apache.felix.framework.BundleWiringImpl.access$400(BundleWiringImpl.java:75)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1955)
at Script1.run(Script1.groovy:7)
MoroSystems Support
February 2, 2018
I think that the result tab shows an output of the last command executed or last variable.
Maybe you are facing the same problem disscussed here https://community.atlassian.com/t5/Marketplace-Apps-questions/Groovy-script-accessing-MySQL-database-works-in-Script-Runner/qaq-p/364831
Vedant Kulkarni
I already go through that problem but that doesn't solve it.
MoroSystems Support
February 1, 2018
are you sure, that you use proper class for MySql db driver. I usually use class
com.mysql.jdbc.Driver when working with MySql database.
Milos
Vedant Kulkarni
I also tried that one but got the same error.
2018-02-01 12:15:41,277 http-nio-8080-exec-5 ERROR vedant 735x347x3 73padh 0:0:0:0:0:0:0:1 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] Script function failed on issue: (create issue) project/issuetype: IFT/Task, user: vedant, fieldId: customfield_10202, file: <inline script>
java.lang.ClassNotFoundException: com.mysql.jdbc.Driver not found by com.onresolve.jira.groovy.groovyrunner [173]
MoroSystems Support
February 1, 2018
Could you provide link to your driver jar file? Where did you downloaded it?
And just to be sure - do you have all required imports in your groovy script as showed in the example from https://scriptrunner.adaptavist.com/latest/jira/recipes/misc/connecting-to-databases.html ?
M.
Vedant Kulkarni
as shown in screenshot I imported the required package.
This is link from which I downloaded the mysql driver
https://dev.mysql.com/downloads/connector/j/FieldTest.PNG
MoroSystems Support
February 2, 2018
uuuh, I am lost :(
The drive file mysql-connector-java-5.1.45-bin.jar looks perfectly fine. It contains com.mysqljdbc.Driver class.
Did you try tu run the script in the Script Runner console? The same error?
What is a version of Jira you are using?
Vedant Kulkarni
Yes, the script is running on console with desired output but it's not running when I tried to run through behaviors
in the logs, I am getting output but in the result tab, I am not getting output. Do I need to write any return statement? so that it will print
Yves Martin
February 27, 2018
Question: have you mapped Behaviour to JIRA project or to Service Desk project (or both) ?
Vedant Kulkarni
I have mapped it to only JIRA projects.
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
