Sample of report"
2017-01-28 02:57:02,773 INFO - Importing issue: [externalId='autoid-4421113524000861838', summary='Story, "Login", 200, , harvinder.singh, Open / Backlog'] 2017-01-28 02:57:02,878 INFO - Importing issue: [externalId='autoid-4570040646771896676', summary='Sub-task, "Subtask of login", ,200 , harvinder.singh, Open / Backlog'] 2017-01-28 02:57:02,961 INFO - Reindexing last 2 issues imported ... 2017-01-28 02:57:03,066 INFO - Reindexing took 102 ms. 2017-01-28 02:57:03,067 INFO - 2 issues successfully created
Try a simple search for "created > -10m" to begin with. In case they're not in the project you expect,
It is also not helping as it shows no issue created. Even if I do created>-1d that also doesnt give result. Further as per success report, if I search by id=200 also I am not getting any result.
Ok, that's pretty clear - I don't think you have the permissions to see the newly imported issues.
If jira admin will import issue then it is required any permission?
If yes then how can I change the permissions.
It sounds like the account you are using does not have permission to see the issues. (Admin rights = admin rights, not "can see/do anything")
Check the project permissions.
