Not able to get issues from the filter using rest api
Vidhi_Jain December 25, 2019
I want the filtered issues from the saved filter JQL. below is the API url:
https://thewarrantygroup.atlassian.net/rest/api/3/search
I have added query parameter:   jql=filter=37735
and authorization token as header with GET parameter.
But I did not find get any data.
{"startAt": 0,"maxResults": 50,"total": 0,"issues": [],}
3 votes
Ravi Sagar _Sparxsys_
December 25, 2019
Hi @Vidhi_Jain
Just to confirm did you check by type the REST API resource url in your browser while you are logged in?
Something like this.
rest/api/3/search?jql=filter=10007
It will then return the JSON.
How are you calling the REST end point? May be if you can share the code then we can take take a look.
Ravi
Hi @Ravi Sagar _Sparxsys_ Ravi, Thanks for reply.
Actually My ultimate purpose is to connect excel with JIRA rest api to get live data.
Yes, I am getting json results when I am hitting the below url:
/rest/api/3/search?jql=filter=37735
To get the same data on excel, I am using Power query from web in excel.
There I set the above said configuration.
Vidhi_Jain December 30, 2019
I am still not able to get output from the search api. Please help me.
Thanks in advance.
Ulrich Kuhnhardt _IzymesCo_
Vidhi_Jain December 26, 2019
