I created a new project and have added a new column, "In review". However, am I missing a step in the mapping? I can't move my items to "In review" the newly added column.
I've looked at project setting and workflow can't really edit or try much.
It also has entries in it already, so I can't copy a template and overwrite it.
Any advise and help is much appreciated.
Jenny
are there transitions in your workflow allowing an issue to be transitions to the new status "In review"?
Best
JP
Hi JP,
Thanks for getting back to me, How do I go about adding transition in the workflow? Do I need some sort of permissions?
Thanks!
Jenny
Yes, depending on your setup you‘ll need at least project admin permissions, maybe even Jira admin permissions.
Best
Jp
Thanks JP.
I have project admin permission. How do I go about adding transition in the workflow?
Thanks!
Jenny
