Number of Issues per custom field
Sanket Mane January 29, 2018
I am looking for a Database query which gives me number of issues associated per custom field within JIRA.
Post a new question
Nic Brough -Adaptavist-
January 29, 2018
You will find it a lot easier to do this with JQL.
Run a query for "custom field is not empty".  It'll give you the number of issues, and normalised for multi-option fields.
Our instance of JIRA has more than 2000 custom fields. So, doing it manually would be a big task. Any quick solution for it?
January 29, 2018
Mmm, some will tell you to reach for SQL, but it's only going to do some of the work.
For single-option fields, you can get somewhere with
select count(customfield) from customfieldvalue group by (customfield)
But I'd only use that to identify low usage fields.  It won't help much with multi-option fields, and won't tell you anything about zero usage.
I'd use that to clean up as many low-use fields as you can, and list high-usage, then you can use "customfield is empty" to check anything you think might be unused.
When you say single-option fields do you mean single list (single choice) fields?
Your query is not working- can you please elaborate on it.
January 29, 2018
The SQL is a generic query that needs to be adjusted to whatever database you are using, and it's from memory, so I'm not 100% sure the customfield column name is right.
Single-option fields are the ones that have only one entry per issue, so text, dates, single-select, radio buttons etc.  Multi fields are the ones SQL aren't going to be good for - multi-select, labels, check boxes etc.
Database which we are using is MySQL
