Order of execution Automation, Project Automation, workflow post function
AbrahamA
June 21, 2022
Hello
In my project I use the following
  • Automation
  • Project Automation
  • Workflow post function ( before create) i.e. the first transition in workflow
Please let me know the order in which these are executed.
Abe
Jack Brickey
Hi @AbrahamA , I am not familiar with "project automation" so I cannot comment. Can you elaborate?
Assuming a Create operation here is the order...
  1. Post Function - this happens as part of the create event
  2. Automation - this happens as a result of the Create after-the-fact
project automation ???
AbrahamA
June 21, 2022
AbrahamA
June 21, 2022
Thanks for the reply. Here is Automation vs Project Automation locations in the project menu bar.
Jack Brickey
Ok, so this is JSM. The "Automation" is part of JSM specifically. Regardless, my response still applies. I also see this is Server and that might explain project automation. Can you share the type of things you can do under Project Automation? Ultimately the order may depend on the actual automation rule/trigger. Is there some specific objective you have or just generally curious?
Like Vikrant Yadav likes this
AbrahamA
June 21, 2022
Ticket created in JSM , based on the issuetype and the reporter I need to take certain actions.
  • I need to change assignee of the ticket if certain conditions are met.
  • Make workflow transition and change assignee if certain other conditions are met.
So I wrote a post function and then some automation rules.
Jack Brickey
Ok so likely I would simply use Automation for both of these if possible. With that said I would need more precise details of what you're trying to accomplish to be able to offer a direct answer. I don't understand if there is a necessary order to these scenarios. Generally if I am setting up conditions in any transition then I lean to automation versus post functions. Ideally you could do this with a single rule but that depends on the details of your specific use case.
AbrahamA
June 21, 2022
Thanks for providing guidance. This really helps. I cant put details here.
I will accept answer. Thanks again.
