Organize fields in issue layout screen and add panels
Meital July 30, 2020
Hey,
I'm looking for a way to organize nicely the fields in the issue layout (most important on the View screen). Something that allows to organize fields in columns and add panels (like 'Details' system panel that JIRA has). Right now, I have a huge list of fields (and they are not even aligned). I've tried adding tabs in the Screen configuration but it's very easy to miss and requires from users to have extra clicks (which I'm trying to avoid).
Thanks!
Ste Wright
Hi @Meital
Not natively - you can change the order of fields or add tabs, but there isn't alot you can do in regards to field layout.
You could consider using an app to achieve this - such as IssueLayout - or customise the UI using a scripting app such as ScriptRunner.
Ste
Meital August 2, 2020
Thanks! do you know if it's possible using Power Script? I couldn't find any examples.
Ste Wright
Hi @Meital
Their Marketplace listing mentions manipulation of the Jira UI - linking to their help site here: https://confluence.cprime.io/display/JJUPIN/Live+Fields
Ste
