Permission issue
nika gabadze
Banned
October 2, 2024
Hello , I've created security schemes, and now i have issue to see some task , for example someone created task in my organization and use security scheme to not having the access other users , unfortunately he excluded himself form that task and now now one can see that task even the org admins , there are added in the every security scheme ,
do you have any idea how remove security scheme or get the access on that task ?
4 votes
Morgan DUBUISSON
To resolve the issue with the security scheme, you can try accessing the Permission Helper tool. It can be found at the following URL:
https://XXX.atlassian.net/secure/admin/PermissionHelperAdmin.jspa
This tool should help you identify any permission or security scheme issues related to the task in question. Once you locate the problem, you can adjust the security settings accordingly to regain access.
Let me know if you need further assistance!
nika gabadze
Banned
October 2, 2024
Hello , thanks for the info , im on it and ill let you know
nika gabadze
Banned
October 2, 2024
thank you so much , i have found the task and everything , but when i try to edit the permission im getting this err message :
nika gabadze
Banned
October 2, 2024
solved it thank you so much
nika gabadze
Banned
October 2, 2024
it was really helpful
Morgan DUBUISSON
With pleasure, @nika gabadze
If this request is resolved, I invite you to mark it as resolved.
Have a great day!
nika gabadze
Banned
October 2, 2024
okey sure ,
you too!
Lucas Modzelewski _Lumo_
Site note: info on the page is the same if you don't have access or if issue doesn't exist
(to speed up checks you can use /rest/api/3/issue/{ISSUE_KEY} )
To check if it was the last issue created in project you can check if next issue key is higher.
I've run a quick checked and editing correct security lvl I was able to regain access to the issue, so make sure you are editing correct (or all security lvls, to find the right one to make changes)
Fazila Ashraf
Hi @nika gabadze
Welcome to community!
Please try the approach to include reporter in the security level as suggested by Fabio to workaround now.
If you share what type of approach you have used to configure the security levels, could advise you on the best practise to avoid such issues
nika gabadze
Banned
October 2, 2024
Hey @Fazila Ashraf  the user has used this restriction
Fabio Racobaldo _Herzum_
Hi @nika gabadze and welcome,
try to set Reporter in the security level so that each user that create a ticket has, by default, permission to see it.
Hope this helps,
Fabio
nika gabadze
Banned
October 2, 2024
Hello @Fabio Racobaldo _Herzum_  thanks for your response i have already tried but unfortunately facing the same issue , this is how how my security scheme looks like :
  • Project Role (Administrators) (Delete)
  • Project Role (Service Desk Team) (Delete)
  • Reporter (Delete)
  • Project Role (atlassian-addons-project-access) (Delete)
  • Current assignee (Delete)
  • User custom field value (Collaborators) (Delete)
  • User custom field value (Approvers) (Delete
  • Single user (nika gabadze)
Hello @nika gabadze ,
it's weird. Are you sure that ticket has this Security Level? If so, all those users should be able to see it. My thought is that ticket has a different security level with different permissions.
As workaround try to set Security Scheme to none in your project so that all users with browse permission can see tickets so that you can check that specific ticket configuration.
Hope this helps,
Fabio
nika gabadze
Banned
October 2, 2024
Project type is software , IDK because i Added myself in very security scheme which i have at this moment
nika gabadze
Banned
October 2, 2024
sorry , user used this restriction, and first he applied this for administrator role and after that he remove administrator role
nika gabadze
Banned
October 2, 2024
how does this restriction works ? , i don't get it
did u solve?
nika gabadze
Banned
October 2, 2024
yes Fabio and thanks for you attention
