Permissions doesn't work
Joanna Gutowska April 3, 2018
I'm having problems with checking worklogs in some of our projects. I have all of the permissions and I am a main admin, and still I can't see all monthly reports.
For example, I checked user report for March and it showed me 144h. Then, my colleague, who has the same permissions, did the same and 152 hours showed up. As we made reports of all users for whole March I had about 3.5k hours visible and he had above 5k.
How can I fix it?
Joanna
Christopher Jaksch
April 3, 2018
Hi @Joanna Gutowska,
could it be possible that some projects have set issue security schemes and you aren't included in all security levels? This would mean, you aren't able to see all issues of restricted projects.
Please try to check if that's the case: https://confluence.atlassian.com/adminjiraserver/configuring-issue-level-security-938847117.html
Hope that helps.
Best wishes
Chris (STAGIL)
Joanna Gutowska April 4, 2018
Hi @Christopher Jaksch,
this configuration helped, thanks a lot!
best
Joanna
Christopher Jaksch
April 4, 2018
Hi @Joanna Gutowska
happy to hear.
Can you tag my answer as resolution to your question?
Thanks and best wishes
Chris (STAGIL)
done! :)
