Hello friends,
I would like to create a scripted fields in the sidebar to calculate :
I have an example (Screenshot) :
PS: I don't have any experience with Java :/
If anyone can help me with this, i'll be glad!
I'll stay in disposition if you need any infos
Thank you!
Hi @REDA EL HAIDAWI EL IDRISSI
You have to provide a lot more info if you need our help.
What is an "entity"? From the image you provided it seems like you want to add numbers from fields. Is that the case?
The image you provided what does it show? The result of your calculation?
Hello @Alex Koxaras -Relational- Thank you for your reactivity and sorry for the late answer,
An "Entity" in french is like the department, when we say department of development, that is an "Entity".
Well what i need exactly is to show the loads planned and consumed according the department of the users in the scripted fields.
Ex : If some users from the development department and they consumed a sum of 14 days, in the scripted fields will show me : Load Consumed DSI : 14 days
I hope I was simple enough in my explanation.
I still here if you need any more informations.
Thank you so much
