Hello Team,
Is there any way so we can archive multiple projects and delete at a time.
Please let me is it possible in Jira or not.
Thanks and Ragards,
SIddhant Ramteke
Archiving is only available in the data center version. Deleting ANYTHING in JIRA means it is GONE. There is no 'undo' or recycle bin
If you want to make the project invisible apply a permission scheme that doesn't allow any user to have access. The JIRA admin will still be able to see it so they can make it visible if needed for historical data.
Not through the UI. I don't use the API, but it may be possible to do it using the API. If you're no already using the API it may not worth the time to learn it and write the code.
