Can you guide me to the Board Settings?
I do not want to see the SUBTASKS. I only need to see STORY
You could do this by adding "and issuetype is in standardIssueTypes()" to select only story-level issues (or, if you don't want to exclude other layers, "and issuetype is not in subtaskIssueTypes()" ), but this will cause problems with closing the sprint - because you won't be able to progress sub-tasks on the board iinto "done", you'll find stories block you from closing the sprint until you've completed all their sub-tasks.
The best option here is to add a quick-filter to the board, so a single click can hide all the sub-tasks. The filter should be " issuetype is not in subtaskIssueTypes()"
I'm sorry, I did not give you the exact phrasing, I was "thinking out loud" and converting JQL into something a bit closer to natural human language, which the computers struggle with.
I'm glad you made it work, and I apologise for not getting it right. I'd like to think I got you going in the right direction though!
Try to act on the board filter by adding the condition "AND issuetype is not in subtaskIssueTypes()"
Click on the More Actions icon (three dots on the upper-right corner) and select Board Settings.
