Hej Community!
I'd love to know if anyone knows how to change (or if even possible at all) the suggestions of options for the orderable fields in project overview.
Steps to Reproduce:
1. Open a project
2. Check the filtered issues on the left side
3. Open the "order by"-suggestion list by click on the arrow (see picture)
My first thought was defining it through field configuration - but it doesn't matter.
I'm thankful for any kind of help!
All the best,
Elisa
It's a simple alphanumeric sort, and there's a way to change it without code. I don't know if you could inject some javascript to try to change it.
Hej @Nic! Yes, I can do it. But I can't write it but test it. Sorry, I got you wrong. If you could send me a little script to test I would appreciate it.
Javascript is not my strength, I'm afraid I have none that might help.
I'll get beck to one of our internal developers - maybe he can help. But it'll take some time. If anyone else has an idea on how to rearrange the sorting options would be lovely!
Thank you, Nic!
