Post Function - %CURRENT_DATETIME%%
Paolo Palermo October 26, 2017
i've another problem on Jira. Follow the details
  1. I have  custom Field (type date pik) called "END DATE"
  2. I have a post transition on my workflow (when is the final status the custom field previously descriveb will be updated;
  3. In the post function UPDATE CUSTOM FILED i've inserted %CURRENT_DATETIME%% as suggest by Jira/Add-on
  4. The field is correctly updated with the date of transition
Problem
When i try to a query on this field, the query response me always with Zero Element. The problem is that the date is not saved correctly.
Could you help me? I insert e picture for help me in the analisys.
Mizan
October 26, 2017
What result you get when you use
"End Date" > "2017/10/09" and "End Date" < "2017/10/10"
it seems like an issue with "=" operator.
Try to export the result and verify what value is saved in the End Date field . Does it store the date and time value. If yes , this is the issue
Ciao Mizan,
you are right, i've the result. The reason is in the date is present not only date but hh mm : ss
Ex 09/10/2017  12:39:00
Could you suggest me a function in order to have only the date YYYY /MM /DD ? For me is important.
Now i'm using  %%CURRENT_DATE TIME%% function, Exist Current_Date for istance?
Please help me as soon as possible.
Paolo Palermo October 28, 2017
Any News?
Mizan
October 28, 2017
Sorry Sir .. this is the soonest I could reply you.
Sad news is that I dont know the answer for this.
What you want to achieve ?
Is the workaround insufficient .. did you try anything in the meantime ? Made mistakes ?
Did you try to search any other date field or update this date field manually and checked if it works as expected ?
Or have you tried %%CURRENT_DATE%%
Paolo Palermo October 29, 2017
Ciao Mizan,
i didn't found another solution.
If i update manually the custom-field i don't have any problem.
My target is to have query in orther to get Defect closed day by day.
Thanks in advance.
