Power Script for JIRA Live Field cannot get issueType value in create screen
buzz_zhao
March 23, 2021
I am got some troubles using argv["issueTypeId"] like following code:
if(argv["screen"] == "create" && argv["issueTypeId"] == "11201")
finally, I found  argv["issueTypeId"] reture null.  Any ideas?
Widad Dekkiche
July 25, 2021
You could try to do "lfInstantHook("issueType","silScript"). Then use the value of argv["issueType"] in your sil script. It worked for me btw.
Good luck,
Mohammed Monir
@Widad Dekkiche Can I use SIL script to hide issuetype in a project in jira cloud?
Miklos Tix
Awesome, thanks @Widad Dekkiche
It works like a charm! :)
SERVER
