Preformat a field for specific projects
David Whitlock September 29, 2023
Hello, I wanted to know if there is a way to preformat the Description field for specific projects. Specifically, I would like to add 3 questions in the Description that need to be answered. For example, when a user creates new Story, I would to prepopulated these items
Given [condition]
When [event]
Then [Behavior]
I started looking at ScriptRunner behaviors and Custom Script field but nothing really jumped out
Brant Schroeder
@David Whitlock I believe you could use ScriptRunner or JSM.  You would just add it to the workflow in the project on issue create.  This way you can easily have custom values per project.
David Whitlock October 10, 2023
Thank you Brant, I will take a look at that suggestion.
Brant Schroeder
@David Whitlock can you accept the answer to help others?
SERVER
VERSION
8.20.10
