Some of my issues have web links. Here is an example of the result:
I would like to present this information is a column in Structure but can not find the associate field of formula to use.
Hello @Stephen Goulet
It is already possible in Structure for Server/Data Center Jira: you can see all links in an issue(including web links) by adding the Linked Issues column. The Formula column doesn't recognize such links but the Linked Issues column does.
I hope this helps. If you need further assistance with anything, please reach out to us directly at our support portal.
Best regards,
Stepan Kholodov
Tempo
Is this feature not available in the Cloud version? that column only shows linked Jira issues not confluence or external web links.
Hello @Noemi Flores
This is indeed not yet possible in Structure Cloud - there is no access to external links whatsoever. We have a feature in our backlog to allow the Formula column fetching such links.
If you have other questions about Structure, please reach out to us directly at our support portal and we'll get back to you shortly.
Best regards,
Stepan
Tempo (the Structure app vendor)
