Prevent Converting standard Issue to Sub-task
Ismael Jimoh February 28, 2025
I would like to prevent users from converting a parent issue to a sub-task if the selected parent when converting the ticket is already closed.
I have tried with a validator but this didn't stop the following from proceeding.
if(parentIssue.getProjectObject().getKey() == 'projkey'){
// Check if the parent issue is closed
if (parentIssue != null && parentIssue.getStatus().getName() in ['type1', 'type 2', 'No Issue']) {
throw new InvalidInputException("You cannot create a subtask because the parent issue is closed.")
return false
So while this works when a user is creating a new sub-task from the parent issue, it doesn't prevent a user from converting a parent issue into a sub-task and selecting the closed issue as the parent.
How could I check this  to prevent this?
Thanks in advance
Lucas Modzelewski _Lumo_
I've not used this against moving issue, but maybe you can try with workflow properties:
jira.issue.
editable
Make an issue editable when it has a particular status. By default, if this property isn’t set, issues are always editable.
true
Disable editing when an issue has a particular status. This may be helpful when the issue is at the final stage of the process and has some of the finalizing statuses like Done. false
Source: https://confluence.atlassian.com/adminjiraserver/workflow-properties-938847526.html
Let us know if it worked
Ismael Jimoh March 2, 2025
Thanks a lot @Lucas Modzelewski _Lumo_ .
That solved the issue.
I really appreciate the quick response.
SERVER
VERSION
9.4.27
