×Is it possible within a workflow (I would have thought via a condition) to prevent a transition if the issue is unassigned?
Yes, as you say, with a condition.
See the other answer
Figured it out.
I can use a Script Condition (issue.assignee == null) on the transition. Does the job nicely. :-)
how do I add a script condition ?
workflow > click on transition > conditions > add condition ?
