Problem creating attachment in issue via API
Roberto Teresa
October 20, 2023
Im trying to create an attachment in Jira via API using this code but Im getting error 404 not found
   const endpoint = `/rest/api/2/issue/${jiraIssue.key}/attachments`;
    const FormData = require('form-data');
    cy.fixture('../../'+filePath, 'binary').then((fileBin) => {
      const blob = Cypress.Blob.binaryStringToBlob(fileBin);
      const formData = new FormData();
      formData.append('file', blob, { filename: 'issue.feature' });
      for (let [key, value] of formData.entries()) {
        console.log(key, value);
      cy.request({
        method: 'POST',
        url: `${this.apiUrl}${endpoint}`, // baseUrl is prepend to URL
        body: formData,
        headers: {
          Authorization: `Basic ${this.apiKey}`,
          'Content-Type': 'text/plain',
          'X-Atlassian-Token': 'no-check',
      }).then(response => {
         if (response.status === 204) {
          console.log(`Response: ${response.status} ${response.statusText}`);
Fabio Racobaldo _Catworkx_
Hi @Roberto Teresa and welcome,
please take a look here https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-attachments/#api-rest-api-3-issue-issueidorkey-attachments-post
it seems that you are using version 2 and not version 3.
Hope this helps,
Fabio
Roberto Teresa
October 20, 2023
Nothing it didn't worked
@Roberto Teresa the end poit should contain you instance URL. Something like : "https://XXXX.atlassian.net/jira/rest/api/3/issue/{issueIdOrKey}/attachments"
