Problem in integrating github repo and JIRA
Frank Lai
February 3, 2017
I have correctly link my github account with JIRA in DVCS
The repos are correctly shown in the DVCS page.
But there is no automatic sync available for these repos, although I have made corrected setting in it.
When I link the repo with my JIRA project page. It keeps saying "
Linked but not integrated
Your repo is now linked, but your team can get visibility of development progress in their issues when GitHub and JIRA are integrated."
When try to sync with github repo "Failed to link XXX repo with JIRA" was kept showing.
What should I do to correct this problem?
David Wilson
November 1, 2017
I am use Jira cloud.  For me it turned out to be a minor case difference in the url.   I fixed it by going to Administration(gear top right)->Applications->DVCS accounts
(IIRC, you can click the little ! icon and it will take you directly there, but you need to click cancel on the dialog that pops up)
I found the Repository in question and r-click->copy url
Then go back to your Jira project (Link in top right "Back to project: xxxx")
On the left hand pane under source code (where the ! icon is), mouse over the name and click the down arrow that appears, select edit.
Under Repo link, paste the URL.
(You could also try to figure out the differences manually, but this way you are sure to get an exact match).
Success for me, the icon went away!  YMMV.
Hope that helps!
Alana Pradhan
June 4, 2018
worked for me! thank you so much. very frustrating process
Like Justin Lang likes this
Saba August 14, 2017
tried everything! nothing works
F.asanga December 16, 2019
Any idea how this issue got resolved. I have a repo that is not automatically syncing with Jira, despite having all the configurations right. We have been manually doing the sync and was wondering if there was a better way to automate this.
Dina Haines
February 3, 2017
You can connect Bitbucket or GitHub accounts with JIRA using the free JIRA DVCS Connector plugin. This plugin comes with JIRA OnDemand. For JIRA download users, this is a system plugin that you can install. Using the DVCS connector, you can:
  • Link all or a subset of your existing repositories (both public and private to JIRA).
  • Create new repositories and have them link automatically to JIRA.
  • Reference JIRA issues from DVCS commit message and have those commits appear in the issue's Commits tab in JIRA.
  • Transition issues through a JIRA OnDemand workflow (for example, Close, Reopen, and so forth) using smart commit messages.
#Ref: http://www.traditionessaysonline.com/
Frank Lai
February 3, 2017
I am now using JIRA cloud.
I guess it is JIRA software with JIRA DVCS connector integrated already.
But the integration is not working after I link my JIRA account to the github.
What further details do I need to provide in order to find out the solution for this?
Will MacHugh
February 21, 2017
I'm having the same issue. JIRA on the cloud... Github... linked.. but nothing syncs.
fernando
February 22, 2017
I'm having this same issue - should I raise a ticket to have this sorted out?
Susan_Mast
February 24, 2017
We are having the same issue too
Alejandro Guerrieri
February 24, 2017
Same here, it keeps showing "Linked but not integrated" even after going over the authorize process.
Alex Dietz
August 3, 2017
I'm trying to link to a GitHub repro using Jira Cloud, and it doesn't show the DVCS accounts selection at all.  There's nothing to pick at all!
Nicholas Rioux
August 9, 2017
Same issue here. Any resolution information?
Alex Dietz
August 9, 2017
I had the wrong Jira instance.  There's "Jira Core" and "Jira Software Cloud".  Both look identical except for one small difference (guess what?).  Jira Core doesn't have DVCS whereas Jira Software does.   Once I got this worked out the DVCS connection worked as advertised.
Go to:
Administration (gear icon) > Billing > Manage Applications.
That's where I found out I had Jira Core.   Good luck.
Nicholas Rioux
August 9, 2017
I checked that and I have Jira Software and it is still not working. Thanks though, but still have the same issue. Does anyone know if it just does not work with private github repositories?
