I Closed my first Spring and would Start the next.
I am getting the following error regarding the date-format. But i selct the date from the calendar-icon. What i am doing wrong?
Startdatum:Bearbeiten
End Datum:Bearbeiten
'30/Aug/18 10:43' ist kein gültiges Datum. Geben Sie das Datum in folgendem Format an: dd/MMM/yy h:mm a
Hi @Ralf Thieme,
Have you tried changing Jira Software's default language to English?
Also, have you tried specifying the AM/PM after the time?
indeed, i have manually add AM/PM
also, i am working in german language as system default, the english date/time format is another disturbing thing ;-)
Are you able to change to English, found a language issue with the Sprint date format which has no real fix, but instead a workaround.
