a user on my compagny get this error when he trying to send ticket. He try with different bowser like Mozilla & Chrome, but in vain.
He is the only one how get a error like that on the compagny so i now ask your knowledge if someone have a issue.
(The error message say he can't send it because the configuration of the form is wrong.)
I will suggest the best engineering solution of all:
But i don't want to be rude but some times it solves the problem.
If it don't solve it check 2 things:
If the "1" shows the error it's a problem of the machine
If the "2" shows the error is a problem with the user. You may try to check if there is any limitation on editing a fields or something like that
Best regards,
Pedro Felgueiras
i finnaly found the issue, it's because on the Requests collector we have disabled the accound used to create a free ticket.
Thanks you guy's.
Best regards,
