Problem with Sprints
xerintel July 2, 2019
Hi! When I move a Task a other column, the task dissapears!
I attached video -> https://drive.google.com/file/d/1OVXJQcvhZDpc7V47D6PwPUKkr9CIq8tO/view?usp=sharing
Can you help me?
Thans you!
Jack Brickey
...removed unnecessary....
Jack Brickey
Are you perhaps using any automation that may be coming into play?
Where can I look at that?
If it is true that we implement the project through the JIRA API.
Can you help me?
Jack Brickey
Automation would come in the form of an addon e.g. Scriptrunner, Power Scripts or Automation for Jira do you have any of these? Can you answer:
  • are you the system admin?
  • cloud or server
  • Warren’s questions
Hi Jack!
I don´t have automation.
1.- Yes, I am system admin
2.- Server
Thanks. Can you help me? @Jack Brickey
Warren
July 2, 2019
Hi @xerintel
Does this only happen with you? What happens if someone else tries the same move? If only you, check what is different between the other user and you, in terms of access rights.
Did this used to work for you before, or have you never been able to move it?
It looks as though the filter isn't allowing it to show in that state, so check what is in the board filter.
Make a note of the issue key, then when it disappears, open the issue by using
https://company-name.atlassian.net/browse/PAL2-1
and check what status it is in
Okay, we move forward.
The problem seems to be that when you change it, you change the person responsible to Administrator, and that's why it disappears from your Sprint.
