Hi everyone,
we're trying to import some issues in another project but it returns a fatal error:
2024-01-18 17:02:45,621 INFO - Importer started! 2024-01-18 17:02:45,622 INFO - Engine is running in Import mode 2024-01-18 17:02:45,629 INFO - All issues will be imported to project: Change Requests (CR) 2024-01-18 17:02:45,629 INFO - Creating issue: [externalId='autoid-3326588738993817214', summary='On-demand trigger must support IPID (idempotency identifier)'] 2024-01-18 17:02:45,632 INFO - Issue does not have issue type selected, the affected issues will be created with default issue type [Change Request] 2024-01-18 17:02:45,643 ERROR - Fatal error during import java.lang.NullPointerException at com.atlassian.jira.plugins.importer.imports.bulkcreate.engine.BulkCreateDataImporter.doImportIssues(BulkCreateDataImporter.java:241) at com.atlassian.jira.plugins.importer.imports.bulkcreate.engine.BulkCreateDataImporter.runImporterEngine(BulkCreateDataImporter.java:178) at com.atlassian.jira.plugins.importer.imports.bulkcreate.engine.BulkCreateDataImporter.doImport(BulkCreateDataImporter.java:153) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:26) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:15) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:528) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:486) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:216) at java.base/java.lang.Thread.run(Thread.java:829)
The validation before the import is ok, we run also a reindex but the problem still happens.
Do you have suggestion on the root cause?
Thank you,
Emiliano
Please check this page:
Thank you Tansu!
I'd esclude the first cause as we tried to import a basic csv with only Summary and Description and it returned the same error.
So I'll investigate on the other 3 causes.
Thank you again
