Problem with incorrectly generated tissue not being removed
염재영
March 8, 2025
Hello. When I entered Jira, I created the organization incorrectly as follows, but I couldn't delete them. (I am the organization manager (attached to the capture), and the organization doesn't use any products.) The organizations are disabled for deletion as follows, so they can't be deleted. Please delete them. Even if I try to disable and delete the products of the organization, the organization deletion won't work. Please send me an email or answer the question. Organization to delete:
aimatics-team-xrwg68b2
aimatics-team-rmhy0kmz
aimatics-team-gz8f5m3f
The organizations are not being used at all, so please delete them. I checked all the products of the organizations, and I'm telling you that there is no data to back up.
Carlos Garcia Navarro
Hi @염재영 .
Welcome to the Community! Have you followed the instructions here? https://support.atlassian.com/organization-administration/docs/delete-your-organization/
염재영
March 8, 2025
Yes. I already followed the instructions. But I can not remove thats organizations because Remove Button is not active.
FREE
