Problem with issue types
Vasilis Gennaris
I created three new issue types that applies to all my projects. ("Defect", "Reviews/Pull-Requests", "Tech Story")
When i choose one of these new issue types i am then not able to change the type to one of the existing types that existed before the new three.. See screenshots
I am also not able to add Story Points..
Any idea?
Thomas Schlegel
Hi Vasilis,
you can only change an issue type to another one, if they use the same workflow. If workflows are different, you can't do that. Then you have to "move" the issue, using the same project as destination. By moving the issue, you can change the issue type.
I think, your field also is not associated with the new issue type.
Vasilis Gennaris
Hi Thomas,
I have this workflow in use for this project that contains all issue types..
Nic Brough -Adaptavist-
March 22, 2018
The ability to change is also dependent on having the same field configuration for both issue types, as well as workflow.
