Problem with sorting multiple fields in JQL query
Sheri Maxim September 27, 2021
Hello - I have found other questions in the community but the answers don't address my issue. I'm attempting to sort by Parent and then by Status  by using this at the end of  my query: ORDER BY parent ASC, status DESC. The result is ordered by Parent and then Issue Number/Key (example below)
Parent    Status
A             To Do
A              In Progress
A              In Progress
A              To Do
Any ideas as to why?
Andy Heinzer
September 29, 2021
Hi Sheri,
Sorry to hear about this problem.  I think I have been able to recreate this behavior.  I noticed though that where these issues appear to be getting segmented here in my example is along the lines of team managed projects.  I came across this bug ticket over in https://jira.atlassian.com/browse/JRACLOUD-76274
In which another user reports this same behavior, but for the priority field.  I suspect that this could be happening because of the way in which team managed projects don't always have all their fields being stored in a global context, like most company managed projects would tend to have by default. In a team managed project the status might be the same value in name to a different issue in a different team managed project, but technically these are different values on the backend.
Sorry there does not appear to be a solution here, but I would recommend watching that bug for updates here.
Andy
Bill Sheboy
September 29, 2021
Hi @Andy Heinzer
Thanks for that candid and revealing information!  And, that would seem to suggest that the use of team-managed projects in an instance could cause other non-deterministic behaviors with advanced searches.
From the example in this post, if the fields selected in a JQL filter are not available for functions, comparisons, or sorting, what do they evaluate to: null, empty string, ???  This could explain several open JQL, report, and multi-project board symptoms.
Thanks, and kind regards,
Sheri Maxim September 29, 2021
@Andy Heinzer  thanks for the response and explanation. I'll track the reported bug.
Sheri
Andy Heinzer
September 30, 2021
@Bill Sheboy I initially had the same suspicion that fields that might have a null value could be the cause here, such as parent.  However when testing the order by with only the status field, I found I could still replicate the behavior.  So the potential of null values are not the cause of this.
Instead I believe this is happening because of the nature of team managed projects in regards to how fields like status are not the global context field like they are in Company managed projects.
Like Bill Sheboy likes this
Bill Sheboy
September 30, 2021
Thanks, Andy.  I look forward to learning how this can be improved over time.  Certainly any unexplained search results create work for customers and the support team answering their questions.
