Hi everyone,
Here comes my first question as I'm handling with some problems within my JQL query:
project = XXX AND issuetype in (Bug, Test) AND status in (Open, "In Progress") AND created <= -8w AND updated <= -4w ORDER BY created ASC, priority DESC
This query should show me all bugs and tests (I've shorten the query) ordered by created asc and priority desc. This only sorts my list with the created field, but the priority attribute is ignored. This "effect" also comes up when I use another parameter, e.g. assignee asc; no sorting here as well.
... ORDER BY created ASC, assignee asc
makes the list look like:
11.04.2020 employee A
12.04.2020 employee R
13.04.2020 employee J
14.04.2020 employee I
The confusing thing is that they seem to be automatically sorted by issue type?!
I hope, you can support here.
Thanks a lot!
Steffen
Not sure what you are expecting to see here.
When sorting by two fields, the only time the 2nd field is used is if the first field is identical for two issues. Since you are using "created" as the first field, which is believe is a date/time field, unless 2 issues were created in the exact same second, you will never see any sorting on the 2nd field.
Hi, Andrew. Thank you so much for your explanation. It seems I didn't formulate my use case correctly. Your explanation made that clear. Thank you for that. Correct answer!
