Problems with performance after installing the Script Runner plugin
Sergey November 8, 2018
Hey. After installing the Script Runner plugin, the load on the JIRA server immediately increases. With what it can be connected? after disabling the plug, the load goes away.
Henrique Bittencourt
November 13, 2018
Hello Sergey!
Do you have some active scripts within the add-on?
So, 99% of the cases it's not directly the script runner causing the problem, it's going to be the scripts being run by it.
The Script Runner on its own doesn't degrade performance.
What do your scripted fields do? Are they leaking database connections or filehandles or keeping references to stuff somehow?
Make sure you understand if the problem you have is with permgen space or overall memory. It will make a difference on how you increase memory. Groovy can use permgen space.
Best Regards.
Sergey November 13, 2018
HI, From plugins that use scripts only JIRA Misc Workflow Extensions.
