For the sub-tasks that are in Done statusCategory and have resolution set, i see that in some cases progress% is not 100%.
One of the anomalies that i notice for such sub-tasks is -
1. There is no original estimate defined
2. Developer did not log any time against the subtask
Is there a way to make the progress % as 100% even though there is no work logged against such tasks?
Just to confirm...
The estimates / time logged shouldn't impact the % completion of the Subtasks in my experience - it's a count of Subtasks completed.
A few things you can check:
Let us know how you go. Feel free to provide us details from the things to check above, with any supporting screenshots!
Ste
@Ste Wright Thanks for your response.
The structure that i am using is:
Initiative -> Epic -> Standard IssueType -> SubTask Issue Type.
I search the sub-task issues under Story as you suggested. I have 4 subtasks underneath the Story. Added Progress column in results window.
What is notice is -
What should i do in order to get progress = 100% for #2?
See screenshot below. Any suggestions to fix this anomaly at sub-task level will be really helpful.
